HELP!!! Odin stuck!
jharo
379
16
I was trying to do the SPlanner mod and got stuck in a bootloop. So I tried to re-odin flash the deodexed stock rom. No I'm stuck in middle of Odin. What do I do?
How long have you been stuck? What does it say in small white box on bottom left. What kind of computer. Pc or laptop. What ports are you using?
From my Galaxy Note 2 via Tapatalk
Yes, that's right. I was trying to fix the bootloop with Odin. I finally held my breath and unplugged. I just re-downloaded the ROM and it worked...but now it wiped my phone and I have to reload all my apps. PAIN IN THE BUTT!!!
I'm going to have to mention this as a tip. After you root always use titanium backup first thing.
Did you rename the. Odex file before rebooting? Try again before you load all your apps. If it boot loops pull the battery , boot into recovery and wipe cache. Then reboot. Only reasons it would bootloop is if you renamed .odex without replacing the app or if you replaced the app and didn't rename the Odex
Do we have a good working recovery yet? I've been dying to unlock but I'm not bothering until I can do a Nandroid backup(that works)
Twrp is installed when you unlock and works just fine
BekaH
