Help - OK Google sound no longer works
kctony
61
Recently, when I say "OK Google" to voice launch Google assistant, I no longer here the sound indicating assistant is ready for my query. Not a big deal when my phone is in hand, but annoying when my phone is across the room. Same thing happens when I open Alexa. An internet search was no help. Hoping to find help here!
It's happening to me too. Are you able to launch Google Assistant by pressing and holding on your home screen at the bottom? That's not working either.
Yes, that's working fine but no beep or acknowledgement sound when launching that way either.
You can clear data and force stop Google app and then you'll have to turn back on" Hey Google "
If that doesn't work then try Uninstall the update to Google app and update again.
Appreciate the suggestions still no luck on my end.
Try once more to Uninstall the update to Google app but don't let it update this time and test it
I failed to mention, I still get a slight vibration when I say "hey Google."
Do you have multiple devices that might be answering the "Hey Google"?
I'm currently using Nova launcher. It had been working fine and then randomly stopped making the sound when given the command.
Ok then restart Nova launcher if not go to Google app then settings >assistant see if hey Google might be toggled off?
Or try reverting to the stock One UI launcher and see if it still happens.
Search beep topped working for me too S20 5g. Uninstalled google and reinstalled play store version. Disabled auto updates. Temporarily working again. However I expect it will fail again somehow.
ameliadinkins
