HELP PLEASE> System UID's Inconsistent
crwmlw#IM
88
Im getting a screen on the home screen thats says System UID's Inconsistent
UID's on the system are inconsistent, you need to wipe your data partition or your device will be unstable. Then there is a box that says Im feeling lucky that you can click on.
Any ideas please?
Always
LOL. Always downloading apps. Any ideas on which one it could be? Does it sound like an app?
Doing a Google search points to a lot of ROM's installed on the phone, although not all of them, and the end result is usually a factory reset.
Are you rooted / unrooted? Installed any ROM's?
I'm Googling the error, and the end result keeps on showing up as a Factory Reset... I'm not looking through every little detail though... Do some more research, maybe you can find an alternative to resetting...
A lot of the posts also make reference to a file on the SD card... Have you tried removing the SD card and rebooting?
Yes
Yes I did that as well. I had to reformat and lost everything of course. I just want to make sure there is nothing I did to have this happen again.
