[HELP] problem after ROOT my nexus
Ohad Morgan
8
hello all,
i really need your help.
last week I've got my nexus 10 and was trying to ROOT it.
I had some problems with it that i was solved by reading some guides and helpers....
Now I have problem, I think with my SD card (internal storage).
When I try to run Google play I get the message "Unfortunately, Google Play store has stopped.".
When I try to download something from Google chrome I get the message "no SD card."
When I try to run the cam app I get the message "No storage. No external storage available."
I can't see anything when I connect it to my pc, and can't transfer nothing to/from the tab.
Pls help me..
Thanks a lot...
I would say the simplest was is to do a factory reset and don't root it again. Why exactly do you need to root it? Is there something specifically that you need to do that requires rooting?
I did factory reset for many time.
Nothing change.
I did root for some otg options. I dont know if its really need.
Did you move all of your sd to a 0.folder? Android 4.2.2 and up have the users so you have to move everything to a 0. Folder and your sd will be restored see if you can side load es file explorer
Sent from my HTC One X+ using AC Forums mobile app
its complicated...
i try to root and stuck in X nexus logo.
then i try factory reset -> dosent help.
then i have a battery issue -> i read a google guide about battery and succeed to fix it.
then i have my storge prob!..
now if i install a ROOT android i have SU, and if unROOT dont.
what should i do?...
its complicated...
Step by step what did you do details are everything
kctraci1
