Help!!! Red triangle of doom
Levi Alvarado
3
Ok yes im rooted and whenever I go to bootloader screen even trying twrp all I get is hard reset or reboot now with the android laying down with a red triangle and an exclamation mark. Im trying to flash 4.3 but I cant get past this.
I just read a post that might be relevant to your situation but I need to know if you are a Verison model trying to update to ( VRUAME7 )
Posted via the amazing Android Central App
Based on all this; I infer your root (SuperUser) tried to survive the OTA through "Survival Mode" and caused a NaNDroid. Since there's no new root method for your current firmware, you are unfortunately... well... out of luck unless you have a backup of BEFORE you updated, unless you have to wait for a new root method :-(
Don't know if this will work but you could wipe your ROM through a Root-Toolkit on your computer (if you can access the bootloader) and download the one before the update
http://forum.xda-developers.com/showthread.php?t=2292707
(Cannot say it the Official but it dose say *Disclaimer: no apks have been edited this is a FULL STOCK ROM that you would expect to get from verizon*
or you could get a new one. (Good chance to see how Cyanogenmod, Paranoid, or AOKP work for you... if of course you get this far)
All I did was root so far but I didnt back up before I did a root. My phone works just fine I just cant flash a new rom.
