- Aug 16, 2015
- 4
- 0
- 0
warning: block of text coming but I would really appreciate the help
Hello everyone. I got the Samsung Galaxy S6 with a subscription with KPN Provider. This was almost 3 weeks ago. I received my new S6 within days but the phone was getting too hot too quickly for my taste. For simple things such as updating, browsing. Also when I played the game **removed by moderator** to capture the screen so I could broadcast my gameplay through Twitch the phone would reboot automatically very quickly. This happened multiple times and I never even got a warning that the phone was getting too hot. After checking on this forum and other websites I thought my phone was defect so I sent it back and waited for a new one. The phone they sent me after a week was exactly the same one I sent them. It was apparently a "technical mistake" and I had to send it back again so I could get a new one this time. The new phone arrived this last Thursday and immediately it became obvious that this phone suffered from the same "defect". Now though I'm not too sure if it's defect or if every Samsung Galaxy S6 is like this. So I've been keeping track of almost everything. Here is the block of text that goes with it and the screenshots I took. Please Help me because I only have 4 days before I can't send the phone back for a new one. I'm still testing because unfortunately I got sick the past few days. If you need anymore info to be able to help me just let me know.
Overheating problem or not? can't post pictures but I can send the imgur link through pm if needed
Samsung Galaxy S6 128gb White Edition. Firmware 5.0.2 updated to 5.1.1 XEH version from Hungary.
It came with Firmware 5.0.2 and the first thing I did was update it to 5.1.1 through Samsung Smart Switch. Afterwards I wiped the Cache Partition and Reset the phone. I haven't changed anything yet from the System Settings or whatever. Location is turned off though and so is Screen Rotation. No Sim Card in the phone yet.
CPU Temperature. Seems to always be on the hot side even when doing little. I'm using two different apps and they seem to be giving conflicting CPU temperatures.
Right after updating the phone and then resetting it. On start up with nothing else on except for Play Story and downloading CPU Z, the app showed that the CPU was around 54.0 Celsius (1). Cooler Master indicates around 33.0 C.
Updating apps through play store made the CPU immediately go to 79.0 Celsius(2) and has been fluctuating in the meantime between 60.0 and 79.0 Celsius(2). The phone is hot to the touch especially the right side although it's not as if it's impossible to hold the phone. Cooler Master indicates a temperature of 36.2 C (3) and it's indicating that CPU Z is one of the causes of overheating.
It seems as if it's not the download per se that makes the CPU hot but the installing or updating of the Apps itself.
After all of this I decided to restart the phone and just leave it alone for 2 hours. After 2 hours battery was at 15% and the CPU temperature was according to CPU Z 34.0 C (4)and according to Cooler Master 25.6 C (5). The phone felt completely cool to the touch.
I started to charge the phone using the adaptive fast charger and the cable provided. I checked the phone after 30 minutes and the phone was again warm to the touch. CPU Z indicated a temperature of 54.0 C (6), unfortunately I forgot to check Cooler Master. The phone had by that point charged to 55%.
I left the phone to continue charging again until 21:11. By that time the phone was fully charged. The temperature of the phone was 44.0 C (CPU Z ) (7) and 25.9 C (8) (Cooler Master). The phone itself felt completely cold to the touch.
I actually left the phone alone for 3 days in it's box turned on and untouched because I got sick. The battery went from 100% to 93%. The phone was completely cool to the touch.
First thing I did was check CPU Z and the temperature was 32.0 C (9) and Cooler Master indicated 23.7 C (10).
I saw that there were 9 updates available so I updated them all. When the updates were halfway done Cooler master indicated 26.3 C (11) and CPU Z 74.0 C (12)
I will update this with info of the phone and its temperature when I'm playing the game ** removed by moderator**.
