Help!!! Stuck in CWM recovery
Jun 23, 2013
5
Hello, I am a newbie at this stuff. I rooted my phone just fine and have switched between roms constantly but CWM recovery is not working at all on my phone, my buttons will not select anything and i have looked everywhere. Can anybody help?
Not experienced with LG devices, but if it was a Samsung, I would suggest to flash a Stock ROM. That way, you should in theory, start all over.
I don't know if you know to scroll up and down in recovery, use volume buttons, and to select, use the camera button.
What are you trying to do, once able to select in recovery?
I am trying to get to my backup so i can revover and start again but the the camera button does not work to let me select nor do any of the buttons on the bottom. I am just stuck in recovery mode
The zengarden recovery is a great user friendly recovery with the soft keys, it also has options to get out of a bootloop, it has saved me from bricking my phone twice! Go here ... http://androidforums.com/optimus-v-all-things-root/662521-recovery-zengarden-1-6-7-3-t-12-21-2012-a.html You should use this guide ...http://androidforums.com/optimus-v-all-things-root/697813-how-install-flash_image-flash-recovery-rom-theme.html
Also the MiRaGe Rom is the most stable for our phone right now, i think you should give it a try, you won't be disappointed!
I would but the buttons wont work in recovery mode i can move to select but it wont let me select what i need
Are you pushing the camera button to select? When i was first learning how to do this i kept pushing the home button thinking it was the buttton i was supposed to push.
Bilal Nawaz
