HELP! Wierd problem, apps opening realy slowly and sometimes not responding.
Kozuks
3
So I got this wierd problem, like an year, but I didn't find any clue what this means.
Basicly my LG G4 Stylus have an problem for like an year, that mine phone opening apps showing only logo ( like youtube, http://i.imgur.com/s4oIgvG.png ) and gray screen for some games ( like Temple run 2 and alot of other games, some do run but lag, http://i.imgur.com/UTABAJS.png )
This problem started like after 2 months, after the purchase.
The phone is slow and sometimes restarts it self while locked, and trying to unlock it, it takes a while. When I manage to unlock it, its just starting up.
Sometimes the phone goes back to normal like 1 time in 3 months, but after restart it goes back how it is.
This is everything I know about this issue with my phone, I hope someone knows how to fix it!
Thanks,
-Kozuks
EDIT:
I had installed root, and uninstalled, but It still shows that It shows in the Root Checker that the ''root is not installed properly on this device'', I tried installing an another root, the Root Checker it said I have an root, but when I uninstalled it showed ''root is not installed properly on this device''.
And theres always an OS update in my notification area, but when I download It and its ''installed'' at the end it says rooted device.
Thanks.
Hello! Have you tried a factory reset of your device to bring it back to its original settings? Maybe that will help.
I have tried it 3 times, no luck.
I would contact LG online customer support via their website - see if they have any tips for you. If multiple factory resets have not helped, then perhaps you need to send it in.
Just made an E-mail for LG, waiting for reply.
tombwiz14
