ol_jackburton Trusted Member Feb 12, 2017 566 0 0 Apr 28, 2017 #1 never mind, it was an app i had loaded. https://howtoremove.guide/remove-android-ads-on-lock-screen/ Last edited: Apr 28, 2017
T the_munc_e Well-known member Apr 3, 2017 254 0 0 Apr 28, 2017 #2 Re: help with add when charging What launcher are you using?
C cedjunior Well-known member Jun 1, 2013 65 0 0 Apr 28, 2017 #3 Re: help with add when charging Yeah that doesn't look stock. Your launcher is probably spamming you.
VW Maverick Retired Ambassador Dec 3, 2010 5,285 165 63 Apr 28, 2017 #4 Re: help with add when charging Weird. Does not do that on Nova. Mav.
ol_jackburton Trusted Member Feb 12, 2017 566 0 0 Apr 28, 2017 #5 Re: help with add when charging i have loaded no launchers, running all stock
macdarwin Well-known member May 20, 2014 121 0 0 Apr 28, 2017 #6 Its gonna be one of your free apps that you installed that comes with ads and it looks like you installed an aftermarket lockscreen.
LightningGA Well-known member Nov 14, 2010 205 5 18 Apr 28, 2017 #7 Looks like you have ES file explorer I stalled and "Smart Charger" ticked on. It can be turned off in the ES file explorer settings.
