help with cm7.1 gps
ricbon
144
my damn gps signal keeps going in and out on cm7.1 i have no idea what to do, it loads then it goes to the big blue bubble, then the bubble goes away stays where it loaded and it doesnt move, mind you i'm traveling at 75 mph. what should i do? i'm done with flashing different roms only to find a fault i just want this one to work
I've never had a problem with GPS on CM7, but I know others have. Try GpsFix from Android Labs in the market. I've read where it's fixed GPS issues for many folks.
Hope this helps.
Are you on the latest nightly? What different ROMS have you tried?
You may want to bump up the latest nightly with a clean install and see if that fixes it...after you make a nandroid first of course.
pcjordanellis
