Help with cyanogenmod 7!
kevin112996
ok so i just rooted my optimus (love it) and i want to put cyanogen 7 on it. Does someone have a guide on it or know what to do? And for the download link, is the optimus v classified as p999? thank you :D
This worked for me
I posted this in the XDA forums hoping it might help here:
[ROM][WIP][ALPHA] aospCMod | AOSP 2.3.4 / CM7+ (Gingerbread) - Page 225 - xda-developers
Originally Posted by pbailey212
"Everyone this should help, I found it on android central, it will flash the proper recovery so you can get this update to load
http://forum.androidcentral.com/virgin-mobile-optimus-v/opti...ecoveries.html
Sent from my LG-VM670 using XDA App"
I'd like to expand on this. I was having the same problems as most on here with the recovery and new ROM.
Here's what I did in this order:
Downloaded this Xionia_CWMA_12518.4_VM_Recovery.zip from here:
Downloaded this aosp 6-01-2011 ROM http://romshare.deployfu.com/downloa...601-signed.zip from here:
http://forum.xda-developers.com/show...62862&page=221
As I'm running on the Xionia kernel; downloaded this xionia_kernel_014_anykernel_OptimusV_signed.zip
from here:
http://forum.xda-developers.com/show....php?t=1024876
Key swap on Back and Home button (for Xionia kernel) is this Optimus_V_Key_Swap_signed.zip
from here:
Put all four .zips in root of SD card
Flashed Xionia Recovery through Rom Manager-NOT as a manual installation-
Xionia Recovery took over and flashed ROM, kernel and finally the Key Swap.
And I saved the best step for last:
DELETED ROM MANAGER!
hey i instaled this today and i try to get on wifi but couldnt for some reason. Is this bc of the ROM? it used to work on stock but now it doesnt even get signal.Can some1 explain please?
Use a newer IHO rom. This rom is outdated.
Sent from my NookColor using Tapatalk
mersy78
