Help with internal phone storage
WalterSobchak
Active member
Sep 9, 2010
26
So I rooted my phone and installed Virtuous 2.7 yesterday, and now I have almost zero internal storage space. Before I rooted, I had like 4 gigs free. What gives?
Are you talking about internal storage space or phone memory? Those are two totally different things.
I assume you are talking about internal storage space? Are you saving everything to the phone internal storage space rather than the SD card?
Internal phone storage not the memory. How do I know if I am doing that? I have all the same apps before I rooted and installed Virtuous 2.7, I reloaded them with Titanium, but now the memory is maxed out. I did the math, even with all the apps I have it doesnt come close to the 6.55 GB it says I have.
Are you recording videos and lots of pictures? Those can be saved to your phones internal storage. That can be checked by being in the camera/camcorder app and hitting the menu and checking the storage settings.
I don't know what else to tell you. Maybe you saved your backup into internal storage somehow. Those are usually about a few gb's a piece.
Maybe download a file explorer and check to see what is on your internal storage? If you don't care whats on your phone storage, you can also format it in Settings -> SD & Phone Storage -> Format phone storage
My storage details are on Virtuous 2.7 are:
SD Card
Total Space: 14.83gb
Available Space: 7.01GB
Internal Phone Storage
Total: 6.6GB
Available: 6.38GB
Phone Memory:
Total: 748 MB
Available: 548MB
Taylor Bag
