help with mms..
suprtong
17
here is my problem..sometimes when i receive a picture message or audio i need to save it to my sd card and view it through astro ..i cant view it through the message the only part im able to see in the meaasge are the words..i have a nexus 1 running froyo 2.2 and im using handsent ..i cant figure out what is going on , im not sure if its a setting or if its on the end of the person sending it or if its the type of file extension associated with it ..does anyone know whats happening?
It is a problem with HandCent, I have too use the basic MMS app in order too save pics.
Regards,
Karnaj
saving them is no problem the problem is i have to save to my sd card than go into astro and locate the file there in order too see or hear what i was sent or else i cant see or hear them .....
Ok I apologize for my misunderstanding of your problem. I have a Moto Droid so I don't have any experience with the Nexus 1 but just thinking about how the Andoid OS works, sounds like the OS isn't seeing the download folder. Are you rooted and or running a custom rom?
Karnaj
Sent from my Droid using Tapatalk
Karnaj
im running the stock 2.2 froyo that is downloaded from google..i never messed with the os myself
Okay I am also using Handsent, but I have the Evo when I get a mms I am able to view it right in the thread without saving it so that is weird.
I havent seen this until I last updated handcent. Previously the pictures just showed. Now they all have a download button. After a few tries, I just figured it wasn't working and stopped trying, I had expected them to appear in the message after I clicked download. HMMMMM.
I have an Evo by the way. Is this what is happening to you?
