Help with navigation. Please
crwmlw#IM
88
Ok I have a Droid Incredible and I noticed today when I click on the Google navigation I get a message that comes up that says " checking navigation availibilty" and just stays that way. It doesn't matter what my location is. Any ideas please?
Uncheck Google location services, see if that helps, I have an app that if that is checked gps location is a problem.
Occasionally Maps can not get a GPS fix for me. I need to open another app and find my location using that app, then Maps finds me. I have MyTracks for example, for running, downloaded.
Have you cleared the cache is the nav app?
Menu -> Settings -> Applications -> Manage Applications -> Select "All" -> Maps -> Clear Data and Clear Cache
I uninstalled and reinstalled the latest google maps update....that worked
EnigmaDragon
