help with recovery
dedeandmaddog
66
3
when I try to boot into recovery I get the android exclamation and have to do a battery pull to reset my phone. I would guess that this is because CWM recovery is not installed however in my ROM manager shows me that my current recovery is CWM 5.0.2.0., and I do remember flashing CWM recovery. so I am not sure what the problem is.
I re-flashed recovery and all is working. still not sure what made it go away in the first place though.
ROM Manager at work once again ..... sigh....
Have you tried to boot into CWM manually from a powered off state or are you attempting to do so via ROM Manager?
I have tried both. It is now not working again. I was able to reflash and back up current rom and everything went as it should. But I thought I would double check before I flashed a new rom and it didn't boot into recovery again. It seems like it is deleting recovery every time I attempt to reboot into it.
