Help with ROM Manager
Unrevoked doesn't unlock Nand I believe and that's required to install CM6.
Sent from my HTC EVO using Tapatalk
Hey man, so did you start out with Unrevoked 3 in yours? Now you are running a new Rom? What were the steps that got you to this point now?
I rooted using simpleroot2 idk why but I didn't get super user status from it so I used unrevoked and then I was able to flash roms. If you want to flash roms you need full root. Idk if you can simple root but if you can do it. Its awesome.
I have a question, I don't like clockwork recovery my favorite recovery img is AmonRA , ROM MANAGER let me install amon ra via rom manager or only can install clockwork ?
All the way at the bottom of rom manager you will see "flash alternate recovery" click that and it will flash AmonRa
Ok, Can I use Amon_RA and install ROM via rom manager, or rom manager only works when I have clock work installed ??
Only clockwork will flash from rom manager. I use AmonRa. Clockwork is known for not wiping correctly. So better safe than sorry I say.
help me any one..........
so i just rooted my evo with simpleroot and i flash clockwork recovery onto my phone. i did a nandroid backup with clockwork in the recovery mode and everything work. now i downloaded rom manager free and i tried to do a backup trough rom manager and i get "an error occurred while attempting to run privileged commands"
i know i am rooted because i can go into clockwork recovery and also when ever i boot up i get a custom boot loader
any help please
any help please
Check SuperUser to see if there is a green or red light next to Rom Manager. You have to be NAND unlocked for everything to run properly.
any help please
fix permissions.
any help please
Install SuperUser from the market... then run ROM Manager and install the Clockwork recovery again. You will get a popup to grant root access, tell it to allow and it should work. Fixed me up, had the same issue regarding it attempting to run privileged commands after rooting using SimpleRoot.
sikkman859
