Help with root
Just went back and looked at the Revolutionary site and figured out where I went wrong. Her T-Bolt is now rooted! Now how do you load a ROM lol?
Use the sticky at the top of this section, all you need for backing up, restoring, and flashing Roms...with screenshots...its a thing of beauty for first time footers just used it last week also with no fail
I want to load Gingeritis 3D but I have a few questions. The phone currently has the OTA MR2 radio update. Is that the radio to use with this ROM? When they say to wipe data are they talking about in CWM or doing a factory reset on the phone? I know that you have to wipe the cache inside of CWM.
That radio will work... but you can load just about any Gingerbread radio... I have not found one Gingerbread radio that did not work with that ROM... there are a lot of them out there... check out the link in my signature.
Yes, CWM Recovery has a Wipe Data, then Wipe Cache, then under advanced do a Wipe Dalvik Cache... then load the ROM... after it's loaded boot up... this is the best source: http://forums.androidcentral.com/thunderbolt-rooting-roms-hacks/77350-guide-how-backup-restore-install-roms-thunderbolt.html
Aruz530
