Help with rooted apps
Ok now this getting weird. When i flash the custom rom again and tried to install busybox again it wouldnt let me..Im starting to think its this the rom
Stop.
NO really stop.
Flash your stock rom.
Walk away from the phone for a couple hours.
Now what rom are you trying to install?
Are you following the exact steps given in the roms instructions?
On your rooted stock rom do you get the error saying you cant install the root required app?
Open the superuser app up and check to make sure the apps are allowed SU access. Even if you clicked the popup sometimes it will deny them access.
Another option is to try to install rom manager. If it installs, open it up scroll to fix permissions. Click on it it will ask if you really wanna do it. Select yes and give root access. If you cant do this then your phone is not rooted properly. I suggest rerunning gingerbreak on the stock rom.
I guess thats what it was cause it said error after I gave it root access..Im try to root it on the stock rom and see what happens. And I installed a gingerbread rom
How bout that!! It worked with that ROM..Guess ill be using this one for the moment. Thanks for the help
What rom where you trying to install? I swear to all things android if its one of outdated roms Im going to scream.
It amazes me how people will dig up one of the old roms and try to install it.
MWavy06
