Help with Routine - changing Sound Mode
k os
52
15
8
I normally keep my phone on vibrate, especially during the day while working. However, I'm trying to create a routine for specific contacts that detects Sound Mode is vibrate, it should change notification volume, give a notification sound, then return to vibrate. However, it doesn't work. Here are my steps:
  • IF (all conditions met)
    • Message received
      • List contacts
    • Sound Mode
      • Vibrate
  • THEN
    • Sound Mode and Volume
      • List volume for each setting
    • Wait before next action
      • 1 second
    • Beep once
      • 1 second
      • Vibrate
I basically have do not distribute almost always on, and then within the do not distribute settings I allow (via use of starred/favourite contacts) only those to ring through. Vibrate or not is I think also settable within do not distribute.
Lemme look into that option. I prefer *some* notification (vibrate) but might be able to make this work.
I think the issue I've run into with DND is that it also prevents all notifications on my watch. I'd like my watch to still vibrate. I'll ignore, unless a sound is made for my very important contacts, hence the idea behind the routine.
Apologies, that quite possibly could be important. I'm using an S24U.
I'll move this for more specific traffic to the s24 Forum.
Have you tried modes and routines in settings?
Bump, hoping for suggestions.
I tried it and also ran into problems. For me, first thing I noticed was it wouldn't trigger on message received from specified contact. So, I changed that to trigger on any notification from messages app with text that included the name of a specified contact. That seemed to work as a trigger, but even though the routine would switch from vibration to sound, I didn't hear beep and the routine didn't result in switching back to vibration. I then ditched the beep and the waits, and instead just set it to display a custom notification as a test action. That seemed to work, and to also permit the routine to complete to the end to switch back to vibration. At one point, I replaced the custom notification with an action to turn the flashlight on, wait 5 seconds, turn flashlight off, and that seemed to stop/fail for turning the flashlight off or the wait. So, I ditched the wait again and it seemed to then work to basically "flash the flashlight" when the specified contact messaged me, while also completing to the end of the routine to switch back to vibration. I also re-tried some beeps as actions at one point, but for me that didn't seem to work and I don't remember if I was re-trying with or without waits (and to be honest I started getting more interested in just confirming that some of the logic could work as opposed to which specific logic would or wouldn't, so I didn't dig deeply back into the beep).
My guess is certain things don't always fully work in routines for some of the triggers and actions, or in certain combinations/scenarios. I have previously noticed that certain things are sometimes not available for selection depending on what other things are selected in a routine. And, to me some of how the Ifs/ElseIfs are available don't seem to follow natural expectations.
I think when something fails in a routine, in some cases it might now just stop and exit the routine without trying any of the remaining steps. Previous, I have seen routines provide indication of errors or failures, but maybe they don't do that anymore (I didn't receive any error or failure indicators when trying things and had to basically rely on my own artificially inserted indicators and from my own observations, to try to determine where things might be getting hung up. The failures of the waits (if that is part of what is happening) seem particularly odd to me because I'm pretty sure I've played around with those successfully before.
I suggest you try lots of trial and error to see what you might be able to get working for your need via routines. Or, also reconsider use of do not disturb and for notifications from favourite contacts to punch through the do not disturb.
Reactions: k os
I need to try trial and error, because I tried DND and the issue I ran into immediately is no volume in apps, like TikTok, for example.
Yeah I think DoNotDisturb would normally do that, unless you otherwise set it differently.
I completely missed that option. I think I'll give it another try. Thanks.
I suggest you also check back after OS updates. After my last update for example, routines seem to now give some indication of where/if/why certain steps fail.
Reactions: k os
Where did you find this notification? Did you have to go into Mode and Routines to see an error? Or was it an actual notification?
Not a notification, per say. The one I saw this morning was in where one edits and defines the triggers and actions of the routine, a small red exclamation point with a circle around it, and when I touched that in my case it told me it couldn't set screen brightness because such conflicted with also a setting for power saving (allowing me to just reorder those two around). There seems to now also be some error indications in routine and mode history lists.
I've seen the exclamation mark after updates, but only for something that is no longer supported. Will pay attention to it more. Thanks.
For my example I earlier saw, it wasn't about something not supported or depreciated. Instead, it was when I had set conflicting actions (which admittedly only seemed to becoming conflicting as a result of the OS/UI update), and the indication was quite useful to allow me to conclude that I simply needed to change the order of the two actions to make the routine work again.
I have not retried your original routine intentions, to see if the indicators would now help me troubleshoot for why the routine doesn't succeed.
BrüZZi
