I'm not sure what you mean...but I usually just hook it up to computer and transfer from external sd to computer. Or you can use a file explorer and transfer/copy/save To internal storage on phone... then when you put in the new sd card you can transfer them back to external sd...but be careful...since KK some people say the phone will not show images and music file from external storage unless you use a third party app that is up to date and can find the info on your external sd...I would definitely store all info to computer and make sure you can view it before getting rid or moving anything on just the phone.
Oh I forgot you could save them to a free cloud service and just view them from there if you don't want to hook to computer...just select the images and select what cloud service you want to share them with...drop box and picasa give like 5 gb free storage and more free if you recommend friends.
