Help!!!
Planoag
I've been trying to recover to a fresh load so that I can correct a WiFi error and an inability to get my bluetooth working. Presently my phone has the following
Firmware 2.2.2
Baseband Ver S;i500.04.V.ED05
Kernal Version 2.6.32.9
Build # SCH-I500.ED05
I've been trying to use Odin V1.3 But I'm not sure if I have CMW? The phone was rooted by the previous owner.
So, How do I get to a baseline working version of software that makes everything work properly again? Thanks in advance for your help for the nubie :'(
All you need to do if you are familiar with ODIN is get the tar file of the stock ED05 build and ODIN it on your phone. I'm not sure if it's linked on AC or not, but I know you can find it over at XDA.
Alright I Odin the CI500_VZW_ED05_FROYO_REL.tar.md5 file and undortunately my Wifi and bluetooth still do not function and the about page still says
Firmware 2.2.2
ODIN says everything went in fine. I don't understand what is wrong with the phone.
Some more help?:confused:
Firmware 2.2.2
Do exactly what you did in odin again put put this file Pit File where it says pit, and MAKE sure to check the Re-Partition box as well. then flash as usual. Let me knwo if that fixes what ails you.
KidColoringPage
