Help.
Thank you, and do you know where I can download a recovery? I have CWM and I'm trying to install the ZM9 security update!
im using the kernel now on iho. no issues at all.
EDIT: READ CURTIS READ!! ...no dont install the radio update...pure garbage from vm imo...as for bobzhome kernel,with or without the radio update,its a good thing to have imo.
So is it not worth flashing the update? I read that it helps reception. Is that true?
Nope. For a lot of people, it had no real provable improvement and in fact ruined their phone with stability problems, random reboots, and unreliable texting. Avoid at all costs, I wish I never updated :\
Reactions: braxton355
The rebooting while testing/calling issue has seems to be solved and it has helped at least some people's signals. I did it and only had a few reboots even with the old kernels.
Edit: Also I posted a link on the radio update thread for the stock zv9 recovery its what I use when I need to flash the zv9 update.
I'm just not gonna do it. Maybe in the far future! But I'm gonna take the communities advice for right now. Thanks guys!
BrüZZi
