Help
Alex Pearsall
18
I heard google drop the xoom:'(:(:(:'(:'(:'(:(
do you still think it will be able to get key lime pie root or no root
And is it still worth buying
There will be no official updates for the Xoom. CM10 is the best option to move forward. It also has multi profile support too.
Sent from my Xoom using Android Central Forums
When the supposed Key Lime Pie version of Android releases, the XOOM probably won't be on the upgrade list.
Its guaranteed, a developer will probably create a unofficial ROM of Key Lime Pie however.
Sent from my MZ604 using Android Central Forums
They weren't considered google experience devices so the update was left to Verizon to say yes or no. They said no last I read but I can't give you a pointer to a page that confirms that right now.
Sent from my DROID RAZR using Android Central Forums
KidColoringPage
