help
Sep 14, 2013
8
so i bought a blu touch android tablet i got a sd card its showing up in the settings but its not let me use it an help thanks
Use it how? Stock Android won't let you install apps to an SD card. You can put media there like movies and music, but not apps. Google doesn't think apps run properly off SD cards and I generally agree with them. This article may help you though considering the low amount of internal storage you have: How To Install Apps Onto Your SD Card (No Root)
ruhidubey017
