A Azucena Martinez New member Feb 5, 2014 1 0 0 Feb 5, 2014 #1 My lg optimus m plus wont read sd card
B. Diddy Senior Ambassador Moderator Mar 9, 2012 169,741 11,159 113 Feb 5, 2014 #2 Welcome to Android Central! Did the SD card ever work before? Have you taken the SD card out and tested it on your desktop or laptop? You may need to reformat it in your computer, then reinsert it into your phone. Or the SD card might just be bad.
A Androidbot101 Member Jun 14, 2014 7 0 0 Jun 15, 2014 #3 i have the same prob but for the lg ms 690 the card reads on the pc but not on my phone
C Cheryl Meow New member Nov 5, 2014 1 0 0 Nov 5, 2014 #4 Check the size of the SD card. There is a maximum size that the phone can read. Look it up.
