Highly recommend enabling ART.
Just played around with a friend's n7 (2012) and he is noticing there are instances of lag worth the new update, I recommended switching to ART caching but it wasn't available.... Any recommendations?
Posted from my "CrackDroid" Nexus 4 via the Android Central App
ART currently support only Qualcomm devices, so not available for Tegra and Exynos devices. Recommendation is to buy the 2013 edition.
sent from tapatalk
Re: Google Nexus 4 - Highly recommend enabling ART.
Darn...
Sent from my "CrackDroid" Nexus 4 using the Mobile Nations App
ART is incredible for battery and performance
I'm not seeing better battery life after switching to ART. Apps load noticeably faster though. I'm happy with it so far.
Biggest change I noticed with ART enabled is that it makes apps 20% larger, I used it for a couple of days then switched back.
Really? I knew it made apps larger, but not that much. I still have a lot of free space so I'm not concerned with that... right now. Something I'll keep my eye on though.
No ART in Nexus tablets, tried with my N7(2012).
Not true. The Nexus 7 2013 model has it. As another poster stated, it is not available for Tegra processors, which is why the 2012 does not have the option to enable it.
I have not enabled it yet on mine as I kept reading about crippling bugs, though I am seeing a lot more apps receiving compatibility updates and growing numbers of reports that it is a big improvement, so I am going to try it out. :)
Anyone here flash the motox Qualcomm thing? Seems pretty fast to me. Hard to tell a difference between that+dalvik and art.
Here's the link if interested
[4.4][PATCH] Qualcomm-optimized Dalvik & Bionic libraries - xda-developers
Sent from my Nexus 4 using Tapatalk
There are roms that integrated that patch like 'Pure Speed X'. Samsung using similar optimization to help them cheat on benchmarks, you will see your Dalvik score goes higher with Antutu benchmarks (I don't recommend relying on Antutu benchmarks, especially for KitKat and ART yet), but you won't notice as much for real life usage, but it doesn't hurt to flash it. For me it's base on how smooth the interface is, how fast apps load, the overall stability of the OS and the battery life, KitKat with ART does it for me.
Can't seem to use ART if rooted.
I meant fast in terms of ui. I never check benchmarks.
I just started up a thread about seeing performance differences between Dalvik and ART. I have seen absolutely no difference in performance between 4.3 Dalvik, 4.4 Dalvik, and 4.4 ART.
There's likely subtle differences that are not noticeable to the eye, but are noticeable on the various testing mechanisms for such runtimes. Regarding ART, people are reporting improvements. However, there has already been a lot of talk on the issue and most (if not all) conclusions are that ART provides for no improvements over Dalvik and is included to allow developers, OEMs, etc. the opportunity to start enhancing there hardware with the new runtime.
I believe you're right. Apps load faster, but that's about it. No difference in battery life, system speed or really anything else. Downside is that it increases the size of apps considerably.
I got far better battery life with ART.
I already get really good battery life... especially with the 4.4 update. Actually.... I don't believe I could get any better. The thing I don't like about ART is that it adds to the size of apps considerably. I'm still using ART for now.
I got 20 mins extra on screen with ART, which is significant. Only reason I'm not using ART at the moment is because ART doesn't work wither with a rooted phone or a phone with a custom kernel.
Why does it add significantly to the size of apps? Some of my apps doubled in size.
ART work fine with rooted phone or custom kernel. Don't know what you're talking about. I can prove it.
You need to use odexed gapps.
Sonfollower28
