Home Replacements of choice for RAZR?
The one problem I have had with home replacements, and that is with launcher pro, and adw.
Ist that I cant change the default. I have to say that I do like the widgets on the moto skin better. But I am so used to the app drawer being in the middle. What the heck?
But yes I would like a home replacement that would allow me to change the default setting back to the original. Any suggestions.
Thanks......................
expand on that a little for me so i can understand
Sorry guys but Zeam looks boring. I have a Droid Charge and I've been running Go Launcher since day 1 and love it. Best one out there. Does everything stock launchers can only dream of. I also prefer Go Keyboard to stock and Go Weather is awesome looking. Go Locker is cool too. Everything is practically free compared to Launcher Pro. Right now I am trolling the Razr and Nexus sites for battery comparisons so I'm a little off task but Go Launcher products are the way to go. These pics show you just a couple of a dozen possible transition styles and endless customization possibilities. Notice that not only do I change my wall paper but I can also customize the docks back ground at the bottom. You can make the wallpaper in the app drawer different and make the app scrolling transitions different from the home screen. You can customize the transition out of the app drawer. You can set swipe motions on the home screen to do various tasks like remove the upper notification bar and the lower dock bar for a full screen operation if you'd like. There is nothing Go Launcher can't do. Limited only by your imagination. And no, I don't work for them. Just love their products. See the pics and tell me what other launchers work like this.
Slight edit: I have seen the delay in populating folders as mentioned in an earlier post but I thought maybe that was my single core 512 ram Samsung causing the problem. Now that this has been brought to my attention, no problem, I'm going to move things I have in folders onto their own home screen which should solve that folder lag issue. BTW, Go Launcher allows up to 30 Home Screens if your into that kind of thing:) or maybe try another folder app like circle launcher along with my Go Launcher. It's pretty cool too.
There is nothing it can't do, except open a folder without lag on the razr.
I agree its a great launcher and I had zero issues with it on my incredible. For some reason it just has issues on my razr that other launchers don't.
Sent from my DROID RAZR using Tapatalk
I was having the same problem on my droid razr (lag in opening folder).
I got a work around for it. Just restart the Go launcher. I hope you know how to restart it but still
Hit Menu Button => More (Top Navigation) => restart.
It takes less then a sec to be normal.
Well I have since found a fix for the issue. Its called Moto Home Fix
There is a bug in blur from what I remember reading that will
not allow the home switcher app to set the original
moto skin back as the primary launcher/skin.
Before I found the fix if u say installed another launcher.
U would have to either uninstall the other launcher
or go to the launcher and clear the defaults.
But playing around and exploring I found Moto Home fix which
alleviates the proplem.
Reactions: thughe1
This launcher is sooooooo good u almost feel compelled to write them and ask to pay.
Easily imo worth 5.00
Yeah I noticed that too. It seemed to only be a temporary fix.
I just installed folder organizer and use that instead.
Um no. I don't care how amazing it is, its an app for a phone, its not worth 99 cents.
I had to think though; in defense of my statement. All the very nice widgets that you can add on to this home replacement that others might nickle and dime you to death for. This app is awesome.
Sticky note widget, calender widget, contacts widget, also like one pster showed the built in effects.
This app is awesome, and for the work they put into this thing. Ok 3.00 :-).
Sheesh SPB Shell was charging 14.00 if memory serves me correctly
Three dollars is a lot of money for something that just changes how you open other apps
I had loaded up launcher pro.no issues, but found myself just going stock. Idk..the "blur" on this phone isn't bad either..very light skin...right now just running stock everything and enjoying it
I agree. I like my Razr the way it is. I use ADW on my Xoom and used several different launchers on my Incredible, but so far, I have no desire to change my Razr from stock.
tanvizen023
