Honest battery evaluation
I don't get how people get 15 hours or more battery life..I am on 52% after 3 hours of use..on stock ics...screen brightness on low...power save mode on...can't figure y everyone is getting such great bbattery life...smh
Sent from my SCH-I535 using Android Central Forums
Lookout can be a system hog especially if you use all their services like antitheft and web related services. Keeps maps going ie. gps. Keeps OS and System running checking all your social, email and web all while screen is off.
I also think battery monitoring are battery loss culprits and should not be necessary with technology built into these processors.
Haven't found anything around where I am at to use it with. Being in engineering I spend my time studying anyway. I could see how it would be cool though.
I have those 2 anker batteries coming in, can post a mini review if anyone is interested. Pretty hard to beat for the price.
The price difference with nfc and non nfc batteries is quite a bit.
Sent from my SCH-I535 using Tapatalk 2
Big price difference for sure. I am around several people with the GS3 so we all play with the s-beam feature a lot.
What does the price have anything to do with battery drain? ...
I was just replying to Bond 32 about price differences between NFC batteries and non NFC batteries
---------- Post Merged at 07:00 PM ---------- Previous Post was at 06:55 PM ----------
So uninstall lookout mobile security?
I don't want to tell you what to do with your security but you can experiment with others. I personally tried several and ended up with Norton. Which helped my battery usage some but its a lighter app and I dont use the extras.
Thank you..I appreciate the tip..I have juice defender and that some what helps..I deleted lookout mobile security..ill try some other things and get back to you..
I am seeing great battery life, and I use Lookout, with all the security settings on. I also have LTE just about everywhere I go. I will know better after about a week of use, but I am satisfied so far.
How? I don't get how that can be when u and I have tthe same phone
racoo
