HoneyBun-v1- based off official ruu
How many uninstall Sprint tv
  • Total voters
  • Poll closed .
thanks for the stock colored espresso beezy, looks fantastic......I hate to keep buggin you about this but this will be my last request I swear! lol....is there anyway you could put the green espresso and clear lock bar screen together? when i flash them they overwrite each other so i can only get one on at a time
I got ya,I can't get to it tonight but will do first thing in the morning.
Hey everyone working on v.2 trying to get iit smoothed out then ill get it up.
*Added a poll if everyone could please give there input would be greatly appreciated,thanks.
Beezy
Y'know... I voted doesn't really mattered, but then realized mebbe I should clarify that. I never ever use sprint tv. Not once. Just not interested. But I've never gone out of my way to uninstall it cause.. well I'm lazy.
I wouldn't miss it one little bit if it was gone though.
Beezy
Ha, I just saw your poll and had to look at my phone... I didn't realize sprint TV was still on the lite version... I just assumed it was one of apps you had cut in v1.
still no dice on the widgets with iced...
is the oc flash posted a few pages ago still valid?
also, how do i check the OC flash/ check the speed?
im only getting 2.85mflops on linpak...
Im still trying to tweak the friend version,to get HTC widgets to work. If you follow the link on first post there's a newer version of oc made by darch that should work better. As to check speed linpack or neocore. The highest I get in linpack without oc'ing 2.2 so 2.8 is a good gain.
I was going to cut it,but i figured too many people probably use it so i let it in there.You can remove it or any of the stock apps with astro(any file manager will do).I use astro and backup tv and navi then i uninstall till i need them saves sum room,cause navi is like 5mb.
i fugred it out, i bumped up to 768, and am getting 3.1 in linpak now...
widgets dont work in non-friend iced either...but is uppose if you get one working, the other should be easier to sort...lol
Check second post just put it up.
The widgets should work in the non- friend version they work for me and a buddy.You might have to wipe to get them to work if coming from friend version.
I wish there were pics lol to see but what is the best rom to use here I have downloaded HoneyBun-v.2-Lite and I will be comming from Damaged rom 2.9.1 so full wipe right?
Yeah full wipe is needed. I will get screen shots but all of them look the same as stock the only difference is that some are deodexed.
beezy, just gotta say I love v1 of iced but im gonna try v2. Just hope that it is as good with battery though.
picture.php
Nice i'm fully charging my battery now and going to try and not flash or touch anything(besides normal use) till i see how battery life is.It should be about the same if not just holla and ill try to see whats going on.Also i still have v.1 uploaded just removed the links so if anyone needs just pm me.
Oh don't worry. I still have a copy of v1 here. Plus nandroid. Installing 2 now. Will run it overnight tonight once I get a full charge.
**Small request/favor from someone/anyone will someone post a screen shot of the main screen of either honey/Iced either will do as they both look the same. I woul but i have espresso on and don't want to flash anything till i see how battery life is.
Also before someone ask the pic above yes its a task killer.No i don't use it,need it or even suggest it,im just using it to keep a eye on something will im testing then i will be removing it.thanks
Beezy
unfortunately, wipe of both dalvik and ext didnt do it. still wouldnt install widgets.
factory reset + wipe did however.
Jeez, i hate restoring everything....lol
unfortunately, wipe of both dalvik and ext didnt do it. still wont install widgets.
O'man that does suck sorry,i know what you mean tho. I have to wipe and flash about 20 times a week.lol
so odd. It doesn't make sense, i'm on IcedHoneyBun-v.2-Lite, no problems. Beezy should be posting the "get more widgets" APKs soon in a few different versions, one of which you can hopefully install from SDcard
valldirtg
