HoneyBun-v1- based off official ruu
How many uninstall Sprint tv
  • Total voters
  • Poll closed .
I'd read that the official update patched that outstanding bug that caused the soft menu to pop up when you tapped menu twice to unlock the phone. Still seems to happen for me though.. did that bit of code not make it over to Iced?
if the fc on calls keeps happening try using the one in post 49 of the link. Ill have to check out gvoice somemore not sure which version runs best on the hero i think 2.0 does best. I always forget to dl the app, I only use it for calls and for that you don't need the app.
http://forum.androidcentral.com/htc...-force-close-when-receiving-phone-call-5.html
I flashed the OC you linked to and it fixed both problems. It defiantly fixed the gvoice incoming call problem, now the dial pad is there, and for the fc problem it worked for 4 test calls. That is better that earlier where is f/c'd about 50% of the time.
The kernel I had flashed was the one called OC-kool-aid-boot.zip, if that makes any difference.
Thank you!
I sitting here trying it and it works fine for me that was included in the original update.It shouldn't be doing that.Ill have to check it out but i had the roms done before they put out the patch,so they weren't added in yet.
Thank you!
Yeah theres a little differnce in the two the first one you had,some people report they can't use it.They one i linnked you to seems too be working out for those that were having problems.Its set to 710 instead of 768.
Are you running v1,lite,or friend?
Hey beezy...I was just wondering if you could up the regular Espresso theme (I guess thats what it would be called?) I love everything about the espresso blue one except the blue, lol....I really prefer the light green like in the stock theme...also if you could up the straight bar lock screen that goes with it that would be awesome....thanks in advance if this is possible!
I can do that,ill get it up sometime today.I don't remeber if i already got it made or if ik have to make it,but ill get it done.
Hey everyone working on v.2 trying to get iit smoothed out then ill get it up.
*Added a poll if everyone could please give there input would be greatly appreciated,thanks.
Beezy
Bump added all new versions of roms v.2. Still working on the friend version. Also added a normal green espresso to post 2.
Testings V2, while working with a2sd in ADB i get this...
Code:
# a2sd check
a2sd check
[*] Starting A2SD version 2
[ ] Searching for FirstBoot script...
[ ] Searching for Swap Partition
[!] Swap Partition Found...Turning on swap.
swapon: /dev/block/mmcblk0p3: Device or resource busy
[ ] Searching for Mount Point...
[ ] Mount point found..no further action required.
[ ] Checking for ext partition
[!] Ext partition found.
[ ] Checking Ext partition...
e2fsck 1.40.8 (13-Mar-2008)
/system/bin/e2fsck: Device or resource busy while trying to open /dev/block/mmcb
lk0p2
Filesystem mounted or opened exclusively by another program?
[ ] Mounting ext partitions as ext3.
mount: Device or resource busy
[X] Mounting ext partition as ext3 failed.
[ ] Mounting ext partition as ext2.
[X] Mounting ext partition as ext2 failed.
[X] Can't continue script...aborting.
I have rebooted (computer and phone), redownload, reflashed. Flashed just IHBv2 and no OC kernel, error is persistent.
I use the old version of a2sd.If you do the commands on the first post it should show that data/app has a link to system/sd/app.Do this
adb shell
cd /data/app
pwd
if it returns system/sd/app then everythings good if it doesn't let me know and ill check it out.
adb shell
cd /data/app
pwd
Ah, just saw this. Before I saw this I flashed the a2sd v2.7update 2 from XDA, it now reports correctly.
Yeah, I'm a bit tired, I saw a2sd version 2, and thought it was saying a2sd version 2.7 update 2!
Ok, i guess this means its time for bed =D
thanks for the stock colored espresso beezy, looks fantastic......I hate to keep buggin you about this but this will be my last request I swear! lol....is there anyway you could put the green espresso and clear lock bar screen together? when i flash them they overwrite each other so i can only get one on at a time
sfvsfvbf
