- Nov 6, 2010
- 126
- 0
- 0
The Moto X is always between 87-101 in temp even when I am not using it alot. It went to 101 with driving directions on. Now, doing the same things on the HTC One, it never got above 32. Why is that?
32 Celsius = 89.6 Fahrenheit
Lol. Mixing Fahrenheit & Celsius never a good idea. 90 F I think. Moto X does a lot of stuff with sensors while it just seems to be idle . Running around 100 F probably about normal.
Sent from my SCH-I545 using Tapatalk 4
So the 87-101 is also Celsius?
If it was that hot in Celsius it would burn your hand severely. 100c=212f or boiling water.
Sent from my Moto X via Android Central App
if its 87-10 Celsius it equal to putting it on microwave or a burning burner.
its obviously F....... and OP just compared C vs F
so your Moto X is perfectly fine.
Just to clarify.... is this internal core temperature or the temperature at the surface?
Can you get the temp through built in readings or do you need an app for that?
