How can I access deleted clip tray data?
Guest55
15
Hi I accidentally deleted my clip tray data on my lg android phone, is there any way I can restore or retrieve all the items that I deleted in the clip tray? Thanks
On Gboard, you just have to make sure the Clipboard is activated. Tap the 3-dot menu icon above the keyboard letters, then Clipboard, then make sure the toggle switch is turned on.
Sounds good, thank you guys for all of your time and help! I know what to do in the future now to make sure all of my items that I need stay saved
FahadsTech
