How can I boost sound for calls?
doublestack1
92
Sound boost for calls
Cannot find a way to default the sound boost option when on calls. The earpiece volume is just too low on my VZW Note 4. With the boost option is is tolerable. Any advice is greatly appreciated.
Pete
Re: Sound boost for calls
I believe in lollipop it was removed :( I'm on Verizon as well
Is your call volume low when you use the earpiece? I use mine a ton and cannot believe how low the volume is. I have all the settings set at their highest level. Do any of the boost apps actually work?
KidColoringPage
