How can I fix a Galaxy Note 5 camera problem?
  • Start date Start date
A
AC Question
galaxy not 5 camera problems
So my camera works fine but at the top left corner is the settings button and when i click it i only see the settings for a split second and it just takes me out. I dont know how to fix it. I cant view my settings for my camera while im on the app because once i try to click the little settings icon it just closes it . Anyone else have this problem ? How would i fix this??
Re: galaxy not 5 camera problems
Hiya,
Try going to Settings>Device>Applications>Application Manager
Scroll over to "All"
Goto Camera in the list
Clear Cache > If that doesn't work, go back to Camera Setting (using the above method)
Then Clear Data
Hope this helps!
Andacar
