How can I listen to music via bluetooth?
Kasi,
Once you've turned Bluetooth on, paired the headphones and they're connected, go to Settings -> Bluetooth (press the text on the left, not the toggle on the right), find your device in the list (it should be shown in blue) and select the gear icon to the right.
In the next screen you should be able to enable the Media audio profile.
(My receiver only supports the one profile but your headphones should support two.)
Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk Pro
I recieved a LG HBS-730 for Christmas, I was pretty excited to try with my Galaxy Note but the headset will only connect to the phone audio.. Will not connect to the media. Any suggestions?? My phone has service with AT&T & the headset was purchased at a VZW store, I don't think that makes much difference but it might. Any suggestions would be appreciated.
I use a Samsung HS3000 headset with my galaxy note 3. In my experience Bluetooth music audio problems are normally connected with having to do a factory reset on the phone after a software update, to delete the old Bluetooth files on the phone.
Sent from my SM-N9005 using Tapatalk 2
I had this problem because I wanted to listen to some audios from my website , and I just fixed that problem by searching Android Apps and found an one allowed my to listen to audios using Nokia Bluetooth device which is "NOT Paired"
that application called "Mono Bluetooth Router" it's a free app.
Hey guys,
I bought this phone (loving it btw) but I want to listen to music via my bluetooth. I have tried BT Mono, but whenever I go to play music, it was says "Unable to play during call", and I'm not making any calls. Is there anything I can do to fix that? Or is there any other program I can use?
Thanks for your help!
Any Bluetooth ear piece manufactured in the last 4 years will receive all audio output from your phone so long as they are paired and you have not disabled audio streaming
Sent from my GT-I9300 using Android Central Forums
Both my car system that is Bluetooth, and I'd newer than your post, and basic Bluetooth headsets you buy are phone call only not music, so you must check in the Bluetooth settings if it it's connected audio or music or both
Staff online
sonmaria6
