How can I mirror a smart phone to smart TV without WiFi?
  • Start date Start date
A
AC Question
how can I mirror smart phone to smart TV without WiFi?
I have Sony xperia and bravia TV no wifi but Internet via my phone. I also have chromecast. Is it possible?
Re: how can I mirror smart phone to smart TV without WiFi?
Or a cheap wifi router - Chromecast will need an internet connection to set up (and download the latest update), but that can be done elsewhere. After that you can use it with any cheap wifi router. (As long as it's a supported device - the Z2 and Z3 lines are the only ones listed at the moment, but more keep getting added.)
Unlike DLNA, Chromecast is wireless, invisible in most installations, and just requires running a little free app (Chromecast) to mirror the entire screen to the TV. (Although it looks weird in portrait mode on a 16:9 TV.) I'll never go back to wired.
No. But try using portable wifi hotspot from the phone as the WiFi. Might work
unlucky
