How can I print from my Verizon 4g lte Samsung S4 cell phone to a imagistics sx2100 printer?
  • Start date Start date
A
AC Question
The printer is a Imagistics sx 2100 printer or will I need to use a different type printer?
It depends does it support Google Cloud Print. If yes you can download the Cloud Print app from Play store, set up your printer and use it from anywhere. If it doesn't there is option to set it up using Chrome browser in your computer, you can read more about it on Google Cloud Print website.
scottmscholes36
