How do I add friends on S Health?
  • Start date Start date
A
AC Question
I want to begin using the new "Together" feature, however when I go to 'Select Friend', it states that there are 'no contacts with S Health installed or registered with S Health Together'. I can't seem to find a place to add friends or link to my contacts. I have the latest version...ver 4.8.1.0013.
Both people MUST have Together turned on in SHealth in order for you to see them. Simply having SHealth is not enough. You will not be able to add friends/find if they don't have it turned on. Once both parties have it on you should be able to add them no problem.
That was it, quick and simple. Thank you for your post!
Hello,
To add friends pls follow below method:
1.Save your friend's contact in mobile(not in sim) & your friend should also save your contact in mobile.
2.Add Samsung account
3.Mobile date & time should be correct.
4.Activate Together feature in Shealth(You and your friend)
5.Verify your contact.
6.Send request(Follow Step challenge procedure guideline)
Thanks
This my phone number for s health chalenge:[removed] and my gmail:[removed] pls tell me and add to contact for step challenge
Hello
I have a different question :-) How to remove friends from the list in SHealth? During installation, they add some people from my contacts list which I don't like to be on SHealth list :-(
I don't see any "friends manage" or "remove" option in the menu ...
Hey Guys
i need some motivation to go out n work out daily in order to reduce my weight...
competition is always motivating and inspiring . .
pls add my no [removed] in your contact so that ill show up in the together friends section ..
gulbhahar36
