littlebigman
- Apr 3, 2013
- 47
- 0
- 6
to remove all your screen lock settings go to settings > screen lock & passwords > password > pattern : set the pattern, set the ekstra pin when requested. push the power button twice to active the screen lock, provide the wrong pattern 5 times, choose the ekstra pin and enter the right pin.
This disables all screen lock settings.
Worked for me
Worked for me
Since this page is in the top hits when googling for this issue, I'll add more infos.
My Huawei P8 Lite is currently running the stock ALE-L21C432B594. As shown above, I gave up trying to remove the Pattern lock some time ago because the None option was disabled and nothing worked to re-enable it.
But since it's a real pain when using the phone's GPS when cycling, I gave it another try today… and lo and behold, "None" is now available without my doing anything. Weird.
Anyway, there is no "Security" item in "Settings": It's located under "Advanced settings". It might be because I enabled Developer Mode. The section is actually called "Screen lock & passwords" and it's located at the root when opening Settings.
Worked for me
Worked like magic for me
Thanks for letting us know.![]()
Worked for me
