How do I disable swipe lock when using a pin?
jarsh0322
6
Disable swipe lock when using pin
Okay, so I know that on the s3 I could go into settings>security>uncheck swipe to unlock. Now I have an S5, My problem is I use a pin lock screen set on a 5min delay and have a screen timeout set to 1min so whenever I go to use my phone after the screen has timed out I have to swipe to unlock which just gets annoying. Is there anyway to disable swipe to unlock when using a pin lock screen
Re: Disable swipe lock when using pin
Hmm, On mine I use a pin to unlock and when the screen times out I have to use the pin again to unlock.
Posted via Galaxy s5
kiki2025
