How do I disable teamwin recovery project menu?
  • Start date Start date
A
AC Question
how to disable teamwin recovery project meanu ?
hlw friend , i installed optimus lg g3 rom but when my phone restarted its show a bootloop of Team Win recovery Projects menu.
I am not able to get the phone to boot Android anymore
pls help me
Re: how to disable teamwin recovery project meanu ?
Welcome to the forums. TeamWin is a custom recovery. Since you are booting to that, there might be an issue with the OS. If you click reboot, then system, that should boot you back into Android.
And if it doesn't, you'll have to reflash the ROM. (Do a data partition backup first. That's in there, under Backup. Uncheck everything but Data, then swipe.)
jevakmeni
