How do I get rid of Armor AntiVirus popup??
Recent apps key?? what is that and how did you use it? I have been bombarded with these recent popups now for about 3 or 4 days, and it is bugging the crap out of me
Hold down the home button for recent apps by default
Sent from my SAMSUNG-SGH-I337 using AC Forums mobile app
Hello, I have tried Everything in this thread, and this stupid thing keeps popping up. What else can I try?
I have the same problem. It came after installing some program from playstore. I asked me to change some stuff in system and I said ok. That is why it is now installed inside system of my phone. I also don't know how to get rid of it. I uninstalled those programs but still this add is there. It is "it is adds by Google".
Try this...
settings>accounts>google account. Under privacy there should be an ads button. This will redirect you to a website where you can opt out of these ads. Hope this helps
Great, This worked for me. I have tried everything . Resetting , rooting, apps and nothing worked. Lookout found an app that is preinstalled on the HTC M9EW dual sim called 2048. This little bugger was the culprit. I have disabled it and no more popup ads
Again thank you soooooo much
Regards
tsmtoolpro
