How do I get visual voicemail notification to STOP POPPING UP?
Re: How do I get STUPID visual voicemail notification to STOP POPPING UP!!!!????
Go to your verizon wireless account and use the Block Services option to block the visual voice mail service (there are two options that need to be disabled). They say the downloads for that service wouldn't count against one's data plan quota but I do not believe it.
When I go to see what the visual voicemail is there is a box that states subscribe.So I don't clicl on that because I do not want another monthly fee.So now I still have that annoying notification all the time.Did u check ur bill.It could have a $299 charge for the visual voicemail.
We get voice mail through my work so I didn't want to subscribe but I clicked the subscribe button anyway. The next screen gave me the option to cancel, so I did cancel. If you don't want visual voice mail, but you do want the regular voice mail, I'm suspecting you could follow the same path and have an option to cancel Visual Voice Mail.
This worked for me thanks!
That was awesome, thank you. It was driving me crazy and the thousands of posts were no help! Thanks.
Thank you. I think it worked! It was really ticking me off.
TADA!!!! This has been driving me crazy since the day I got my GS5 last year. I've tried everything with no success ... until ... a few days ago Verizon made available the update from 4.4.4 to 5.0 Lollipop ... FIXED! Yeah. If you've got this problem, upgrade to Lollipop.
It won't update for an Android phone you have to have iPhone
Got a solution (at least if you use google voicemail), so far worked, now I'm trying to spread the word..
Look at the instructions below, they will make sense.
credit goes to JDRCH from another website;
I followed the instructions on this thread, and it didn't work for me.
First, my situation: GS5 verizon (obviously), 4.4.4.
I am NOT a verizon customer, therefore it didn't let me register the visual voicemail.
I'm a Google Voice user, therefore don't need any other voicemail.
INSTRUCTIONS:
* go to: Setting > Application > Call
* scroll half way down, look for Voice Mail Service and choose "Google Voice".
maybe the next step is not necessary, but I did it, easy.
* Go to Google Voice (voice.google.com) on your computer browser (will not work on your cell), go to Setting, and do "Deactivate Google voicemail on this phone" and follow the instructions.
That's it
So then you get no vm at all?
I don't like visual voicemail. I prefer old school and like to listen to my voicemail. I called verizon and told them to block it from my phone. They did and removed the monthly charge.
The way I finally got it off was to go to my local Verizon store and have a employee update my account to remove the free trial and return me to the free version. The issue is Verizon trying to get you to purchase the trial app for a monthly service fee.
This was exactly what I was looking for .... BUT, I can't block it because there is some free trial on my account (just upgraded my phone and plan). I guess I'll keep an eye on it until the free trial is over; then block it.
This had been driving me nuts for 6 months tried calling verizon to deactivate, tried disabling app, even reset phone in desperation nothing worked until I read this post!!! Id get a phone call visual voice mail activation notice would pop up if i declined it voicemail icon would disappear and then i would have no indication i had voice mail at all. I cant tell you how many messages sat for days because i didnt know they were there. Then i came accross your post I can't thank you enough!!! I can finally get voice mail with the little icon and no more stupid visual voice activation required junk!!!! Ty ty ty....
I have an s6. I tried every suggestion here. I tried the suggestions on the Verizon support site. I called Verizon 3 times and got 3 fast talkers who insisted visual was the only option but that the basic was free so basically what was I whining about. But they would (begrudgingly) fix it so the popups would go away. They didnt. In fact they actually began appearing twice a day even when I had no phone calls!
So I called Verizon the 4th time. And what do you know, a person who said i can block that for you and in 30 seconds it was done. It is 100% ALL about the person who answers. Obviously 75% of their hires are either twits or they get paid extra for keeping you signed up but just keep calling until you get a person that will block it. Don't give up, keep calling. Its the only way.
This worked for me. Called Samsung Help at 888-987-4357 . They can connect you by Smart Tutor app to have remote access to your phone to turn notification of Visual Voice Mail off.
Log into myverizon > My Plan and Services > Blocks > Block Services > Block Visual Voice Mail
It is so ridiculous that Sprint has a stupid Visual Voicemail app and it will not allow you to disable it. I don't want it if I want to check my voicemail I will dial into the voicemail system using the number one key. I don't know why they would do something so annoying that you can't can't disable it and can't stop it I don't want it I use Google Voice. It is for this reason that I am just going to root my phone. If they don't want us to root our phone then they need to give us the control we need to stop these annoying things I want my device to be a useful tool not an annoying piece of junk because Sprint decided to put an app on there I can't get rid of nor use
I have gone into the application manager and I can force stop the app but it turns back on. I am not able to turn it off. I have been on hold with Verizon and they told me they were entering a code that would turn it off but that didn't work. I have been communicating on Twitter with @vzwsupport and they were unable to help. This visual voicemail keeps coming back. I don't want it. View attachment 123045
It's been almost 2.5 years since you posted this, but I was able to use this tip to block the Visual Voice Mail on my Droid Turbo 2 by searching for Block Services Verizon on Google, going to it, and blocking the free and Premium. Thank you for posting this.
Been0121
