How do I stop my voice text from repeating everything twice?
  • Start date Start date
A
AC Question
Every time I voice text, my phone repeats the sentence or paragraph twice. Anyway to avoid this annoyance?
Re: How can I fix the "com.android.systemui has stopped" error?
I had the same problem. You only have to unninstall last Google Quick Search App update and it should be fine. Worked for me!
Uninstalling the Google update worked, but now I cannot search Google. So I have to keep installing and reinstalling the Google app. Anyone have a fix for that?
Welcome to Android Central! That's a bit odd -- even if you reverted back to the factory-installed Google app, the search function still should work. What happens when you try to do a search?
I found out what caused it. Earlier today google pushed an update for their google quick search app ( https://forums.androidcentral.com/e...e.android.googlequicksearchbox&token=Jk8W1E_R ), this update broke my home button.
So uninstall the app and you should be fine for now.
Wow thank you so much! I managed to tolerate this glitch for 3 weeks.. I was worried my phone caught a virus! I would not have thought the solution to be this easy! Thank you so much :)
It pops up with another box that says: Unfortunately, com.google.android.googlequicksearchbox has stopped.
So if I update the google app I have internet search capability - but I loose the quick stop to shut down open programs.
Re: How do I fix the error "com.android.systemui has stopped" on my Samsung Galaxy S3 phone?
go to google app on your samsung -> app info -> press UnistallUpdates . belive me it works i had 3 week with this problen and finaly i solvet it
Hi,
I show an updated Jan. 30, 2017 (today) but I've still gotten the same error ("com.android.systemui has stopped") several times today.
I will uninstall & see what happens.
Just want to say this also fixed it for me. I have an S3 with 4.4.2. Hopefully other S3s effected by this update will find this thread, because it took me a night of searching.
Thank you! This worked like a charm...
I have the same error on my Samsung S3. What is the app name that has to be removed to correct the error? Sorry, I could not find an app on my phone with "Quick Search" in the title.
Welcome to Android Central! It's the "Google app" you should be looking for.
I uninstall the Google update and I no longer see the system ui error.. my home button is fine now.. but after uninstalling I see the blue google which is an old version .. plus it says I won't get get Google apps update if I uninstall it .. any idea ???
You can still update the Google app in the Play Store (and, if you have auto-update turned on in the Play Store, it will do so automatically, so turn that off if you want to keep the system UI error away for now).
Thanks so much! I uninstalled Google and then disabled it just in case and instantly was able to use my home button again. Btw galaxy note 2 is my phone.
sukarisw10
