Jaycemiskel
Trusted Member
- Jul 28, 2011
- 2,769
- 4
- 0
I was considering getting one until I heard 3600mah. I think I'm going to get a Moto Z instead. I'll keep my S7e and switch back and forth between that and then I'll sell my S6e
Yeah they have least bloat ware and no ugly carrier logo but still a carrier version. Personally it's still T-Mobile apps, you can't uninstall (only disable), they have certain Samsung features turned off like ability to have all apps on home screen (personally won't do but opposed to carrier's deciding what features should exist on phone). Also T-Mobile recently is very slow in OS updates.
Bottom line for me personally I don't like carrier devices and believe they should just be dumb pipes concentrating on network rather than messing with device hardware and software. I'm looking at the Apple model and commend them for treating the carrier's like the way they should be.
I never did understand this hatred people have for so-called bloatware on the Galaxy devices. I simply create a single folder in my drawer entitled hidden. I then move all of the bloatware apps to that one folder and I never see them again.
I saw that, but can someone tell me is there an advantage to getting the u.s. unlocked version rather than spending $200 less to order the international unlocked version from Amazon?
Yeah samsung pay and most likely warranty. I've heard differing reports on whether or not samsung honors warranty in the US on international models. Look at the reviews on amazon. I never had any issues with my s7 duos but who knows.
If the Note 7 retains the microSD card slot and the IP68 rating as the S7 edge, I'll be ditching my edge for the Note 7.
I felt the same way bout home button after coming from swipe gestures on htc. "Gravity screen" works well using proximity sensors. Unlocked s7 edge is brilliant.I love my S7 Edge except for one thing, the physical home button. I have had the screen buttons for so long I did not realize how big a step backward the physical button would be. The rest of the Samsung universe is just learning. But that damn button ... I should state that I like to use a stylus when home and having to use my finger to press that button disrupts the flow.
Only problem is tmobile extended range lte... unlocked phones can't be used on it so you only get 2g in those areas which where I live is a major issueJust picked up my unlocked version today from best buy. Had used the t-mobile version at launch but hate carrier devices and had returned. Now that unlocked model is available happy to be back on the edge
//uploads.tapatalk-cdn.com/20160701/fb2d16a2220b82cddf8ae2bb58123e7f.jpg
//uploads.tapatalk-cdn.com/20160701/7c84798b8c49ed65f0e9c2f4fbf47912.jpg
//uploads.tapatalk-cdn.com/20160701/5d89e161733dc6a8495e03fed8cfcd0b.jpg
