How do you carry your X?
Naked, and in my pocket. It fits perfectly in the ****ies pants cell phone pocket that I wear to work.
Carry mine in my pocket, screen side in, camera down, Otterbox Commuter with Steinheil Ultra Crystal screen protector.
Do wish there was a holster, but I just deal with it.
I went from Body Glove case with ghost armor screen protector to Otter Box commuter with the GA screen protector and now I roll with no case and just the GA screen protector, always screen side facing in towards my leg.
Cases make it a p.i.t.a. to keep putting in and pulling out of your pocket. I only use the case when I go camping or somewhere with heavy traffic.
there is a holster... i have a otterbox case that slides into a case that clips onto your belt... and i also have a verizon oem leather holster, very nice... and thats what i use... i bought it on ebay for like 12 bucks... but make sure it is a verizon oem and you will end up with a pleather peice of crap...
I have a holster for when I'm at work otherwise its in my pocket. When working I feel like the X takes up to much space in my pocket that I need for other things.
Like many others...naked. I even removed the screen protector film. I'm pretty much treat my DX like a baby as it is, so I haven't had any issues with damage.
Reactions: RandomSF
i have the case and holster deal ( Set Your Location ) that i got from VZW. i like it because when it goes in the holster it's screen is inside for better protection, although i stopped carrying the holster, i just hate carrying one, so i keep mine in the case inside my pocket, screen side against my leg. and i use a screen protector.
Seidio Active case, which I really like, but I cannot find a good holster or belt clip for it to work for me.
I'm a police officer and my duty belt is about 2" wide, My old Storm 2 had a shell/holster from VZW and the clip had a little "hook" on it that hooked right into one of the extra buckle holes and locked it in. I tried a leather holster once with the old phone, I took off running and it made it 3 steps before it slid off the thick belt and I kicked my phone across a street.
So until I find a massive belt clip, I usually put it in a shirt pocket or just set it behind my magazine pouch on my belt and hope I don't do anything crazy and lose it.
Off duty, it goes into a pocket in that same Seidio Active
Checked the Seidio website and apparently they have a locking holster for the Active. It's at the bottom of the page showing the various cases for the X. Here's the link..
seidioonline.com
If this doesn't work for you, do you think one of the Otterbox belt holsters would work with your Seidio? Also, I found the Vz shell/holster (specifically, the holster) is flexible enough to accommodate a number of different cases. Not sure on the Active, though. Looks pretty beefy.
Just a screen protector. If I'm walking for a bit, In my back pocket, if that matters. I came from a Storm 2 and I had no problems adjusting. I mostly only use screen protectors.
How strict are your uniform regs? Can you just order a slightly slimmer belt or maybe order a 5.56mm magazine pouch with ALICE clips? The magazine pouch would work perfectly to hold the X even in a case as big as the Trident Kraken, which would give you a heck of a lot more protection than a Seidio Active. I know there are some undersized belts out there that measure a true 2” and not the common 2-1/4”.
Verizon leathercase, with magnets removed, steinheil ultra crystal screen protector. Kept in front pocket except with jeans- then worn on hip.
Pocket with the VZW Superior Dual case. Looking to get a good hip holster but nothing that fits right with the Dual case.
It's ugly as sin, doesn't have holes for the camera or volume buttons. But was only $3.
Amazon.com: Amzer Luxe Argyle Skin Case for Motorola Droid X MB810 - Smoke grey: Cell Phones & Accessories
I used an exacto knife and cut out the holes for the buttons. I got it initially just to have a case and decide later what I really wanted. It is hard but flexible rubber and is very easy to remove for those pesky battery pulls. Bounces when dropped is a bonus. After trying Body Glove and various other $20+ cases I'm keeping the $3 one. It is well worth the money.
Yoyo01
