How do you remove Picasa albums from phone
Don't have to have the app....it's a picture sync from google and is built in and synced by default.
Go into settings----->accounts and sync---->tap google----->uncheck sync picasa web albums.
Go into settings----->application manager---->all tab----->find gallery and clear data
this is the optimum solution and i test it my self
don't worry this will not erase the files on your phone or SD, it only remove from gallery
once you open gallery it will re-scan content
the gallery is simply an interface that show up your content
the above action will only move the cache and i tried just now before i answer
Thanks guys!
Make sure the synching for the Picasa albums is still off, then go into Settings > Application manager. Select the All tab, find Gallery and hit the Clear data button. Next time you open the Gallery, it will take a moment to rebuild it but the Picasa albums should finally be gone.
Thanks. Great help.
Get on your laptop and go to your Google account. Click on the arrow by your picture on the right side and then click view profile.When your profile loads up click on photos on the left side and click the instant upload tab then delete the instant upload pictures. After you delete it from your account on the computer it will delete from your phone.I did it today and the picasa albums are gone and did not come back. Hope this helps it helped me.
Gracias mi Amigo!
if you do with Gator 352 suggested you will not have to delete your Picasa albums off of your computer. I almost resorted to doing the same thing until I found this thread and what he suggests works just fine without removing your camera photos
Your instructions did help me remove Picasa albums from my Gallaxy III gallery.
Now how do I rebuild the gallery using only wanted Picasa albums?
Thank you.
Thank you.
settings-->applicatoin manager-->all-->gallery-->clear data
Great it's working
thanks a lot....
jags
So glad I found this thread. I never thought to look under my GMail account for picasa syncing. GAH! MAny thanks to the fine people that figured this out and shared with the rest of us!
This process worked for my cell. I have an LG Motion, powered by MetroPCS. Thank you for your assistance!
Charo
Thanks worked like a charm. :D
yep this sure works , the only bit i would add is that after tap google you have to tap your google account #####@gmail.com etc then you will see a list of all the things that google has set up to auto interface switch off as many as you want plus esp the picasa one . yes it works fine all my pics reappeared in gallry many thanks to all
rob805213
