How do you unlock your phone?
  • Total voters
Well, I tried password. Don't like it, anyone know how to reset it, so I can try different way to unlock?
**Never mind, got it.
By the way.... The FPS is easy for me to reach with the easy I hold it even though I mostly use the iris scanner.
Finger print scanner and pin lock. I reiws the ueisbsxannwe a few times. It works ok for me I'm just so used to the fingerprint scanner by now that it's 2nd nature honestly.
For me, facial recognition fails just frequently enough to not be useful. I mostly use smart unlock (trusted device with my fitbit, trusted location at home) but default to fps as option 1a and pin as option 2 if I need to.
FPS backed with pattern. Facial never worked for this ugly face and Iris was hit and miss. FPS unlocks immediately from the AOD screen, the others require touching home button first then scan your eyes/face, to me just requires another step.
Have you tried Iris? I find it quicker and more accurate than the Facial Recognition. Plus you only have to glance at the top of the phone, not move your whole face.
Am I the only crazy one, never lock my phones.
What's the point? I never used to either but unlocking the phone requires exactly the same or even less interaction than having no locking method.
Having no security means you still have to at least hit the power button or home button to unlock it so yeah it's crazy not to now when you could just softly press the FPS or keep your finger on the home button to unlock it.
So if I use fps, I also have to have a pin, pattern or password?
And have to enter one each time, before using fps?
mama baer
