How is the battery life? G3
You keep on saying good, define a good battery for your own use, cause my full day of usage for me is good. I told you what my brightness settings are on my previous post.
How much of screen on time do you get? I'm think that 4-6 hours is good.
This is regular for me. Last night when I plugged my phone in I was at 15%. When I checked my settings, I was on 20hrs 27 mins on battery, with just about 5 hrs screen time.
I only average between 4-5hrs, I haven't reached 6hrs yet.. due to when I stream Youtube/Netflix or other streaming apps, I maximize my brightness to either 75% or 100%
I've just installed a larger 3900 mAh battery, allowing me not to need a different rear cover and loving it.
Today i've beem using my phone for 23 and a half hours, it's light to moderate use and that include : checking facebook, instagram, email, a little bit of fb messenger, a few phone calls, a few texts, few sessions of clash of clans, and checking the phone, i've been on mobile data for about 11 h and 7 h on wi-fi, no signal for about 2h and 30 min aprox (from my calculation), i have live wallpaper (i don't think it's eating too much battery...) with a "wooping" 3h sot, it's not much but regarding the connections and no signal time i think it's ok, not brilliant but ok. I usualy get 4 h sot with heavy usage and 5h moderate to heavy usage.
Posted from Lg G3
What kind and where did you get if from? Thanks
I had switched to ART and wasn't happy with battery life and have tried back on dalvik and battery seems better. It's a wee bit laggy but not outrageous.
Stupid question,but what is ART?
I'm no expert (read loads of reviews suggesting to switch to this to improve lagginess) ibut it's android run time. I believe lollipop uses this by default.
It's inder developer settings. I didn't do any solid scientific testing just felt like battery was going down way too quick for my liking so switched back to dalvik. I only did that a couple of days ago so it might just be a bit of placebo but it feels like the battery is better.
I got the promo deal - free 3000 mAH battery and charger - and the battery is so good I many never use it! I wish I had saved time filling out all the forms for the promo.
Thinking about getting a spare battery and charger, looks to be $21 total on Amazon. Hopefully I won't need it if the battery lasts a full day like all my other phones have.
My battery life is way better after last update on Verizon. I still feel it could be better. I have around 35-45% normal use,,20-10 heavy use. That may be ok for some,but my LG 2 did better on battery than the G3.
First few weeks were mediocre: 2-3 hours of Screen On Time. Now I get average of 4 hours. Not sure if its because I rooted my phone & installed Greenify or that the battery just needed time to calibrate or break in.
My G3 is getting amazing battery life. My phone comes off charge at 5:45am, and with medium-heavy usage throughout the day i am left with 40% when going to bed round about 10pm. Some days more, and some days less, all depending. However i am rooted and running greenify, Xposed framework with the amplify module (prob where im saving most of my battery). I have also set tasker to toggle my gps on and off with certain apps. Obviously not running ART as Xposed is not supported yet on ART. Also still running the stock launcher with zero lag.
I also have the Amplify mod installed. Btw, I'm running Xposed on ART.
I would double check that if i were you. I know if you try change to ART with exposed installed, it reverts back to Dalvik.
I would double check that if i were you. I know if you try change to ART with exposed installed, it reverts back to Dalvik. sorry double post
Are you sure this is legit? With this battery you should be able to easily exceed 5 hours if it is rated at 3950mAh. Do you exceed 5 hours on screen on time? There's a lot of batteries on ebay which claim higher capacity and somehow maintain the same physical size as the original battery which is very sketchy. It should also weigh more, does it?
I have also found that charging time is very quick on this phone. I charged my phone from approx 19% to full charge in about 1hr 45 mins. I thought this very respectable. Way better than my old phone!
richardgroover
