How many V20 users have over the ear "high impedence"??
I am so pissed I missed the promo. I thought a lot of the promo headphones might show up for sale cheap. dumb
Definitely grab some that people got for promo and are selling. They're good but not worth the $149.99 that they go for full retail.
Re: How many V20 users have over the ear "high impedence"??
The AKG K712s are my favorite. The have a clarity and spaciousness that I love and a tight accurate bottom end w/out being boomy. They're also extremely comfortable. The Q701s are the same just with slightly less bass impact. The Senn HD650s don't sound very engaging to me being driven by the V10 or V20. I usually listen to them with a cheap $100 Chinese balanced cable connected to my OPPO HA-1. There, they sound better than I'd ever heard them sound before with a pricey unbalanced Cardas cable connected to my Burson HA-160D. A balanced connection really makes a difference for some headphones.
My favorite headphones for the V10 and V20 are, believe it or not, my Bose QC25s. The bass sounds just right and there's a nice helping of that clarity I'm so fond of. They're very easy to drive being low impedance but they sound good.
Is there a special icon that shows up to let you know when the high impedance mode kicks in?
No, you have to go into the settings and into the Hi-Fi Quad DAC to see if it is in High Impedance mode. Sometimes it will say "External audio device connected" which usually means High Impedance as well.
But they're not high impedence right?
The B&O Play earphones aren't High Impendance, yes. Sometimes they will trigger it in the beginning when you open them (Maybe for a week), but that is bad for the earphones, so you will want to unplug and plug them back in to get Normal mode.
Thanks. I'll have to put one of these on my list for this year.
That's why I said cheap. If I were going to spend $40 or. more I may as well. go for a high impedance model. By cheap I meant like $10. Sore grapes cuz I missed out. I just couldn't make up my mind. The delicate camera lens scared me off for a long time.
The external audio device is a line out setting. It's boosts the gain up slightly but not the same as high impedance.
I can get them from B&h for 219 on Amazon which is the holiday sale price. I got a promo code from B&H to match the price but I have to order by midnight. The current price is 299. I am still undecided especially after I saw this video of model without NC. Apparently depending on the shape and size of your they could have a Hotspot on top of your head.. This guy has to bend them and the NC version has the same issue.
https://m.youtube.com/watch?v=rd8bleLsSfU
The is absolutely nothing to be gained quality-wise by using high impedance headphones with the V20 as opposed to low-impedance phones/earbuds. It all comes down to the quality of the headphones, not whether they're high-impedance or not. The V20 can swing the extra voltage required by high-impedance phones to achieve a given sound pressure level, but there isn't anything inherently better about them.
That may be true in some cases, however Beyer dynamics makes certain models that come in different levels of impedance and they have different sound signatures. Also the gain of the amp changes and that can make a difference in sound volume depending on the sensitivity of the headphones.
Ok I've seen this mode kick in a few times when I connect the phone to the car with the AUX chord. The icon is different and I never could figure out why is was different sometimes and other times it wasn't.
OK, got it
Mike, from the link you'd shared with me earlier if two headphones are otherwise identical and one is of a higher impedance the model with the higher impedance likely has a superior voice coil and that can lead to audibly superior sonic performance. Therefore, and again, the higher impedance model does sound better than the lower impedance model so there is indeed something to be gained. It's is also not uncommon for flagship models to ONLY be released in high impedance versions (think Sennheiser HD700, HD800S, Audeze LCD 4). Fortunately, more high quality cans are being released with low impedance so that they can be driven by lesser mobile devices
I went to B&H today in Manhattan because I was able to convince them to extend the promo price on the ATH-MSR7NC once again and I would get 80 Dollars off the 299 price.
They are a great deal at that price compared to the regular model without NC. I tried on the display model and they were cofortable. First I tried the Noise Cancellation with no music. It is a very crowded store so without NC I could loads of chatter. Once I kicked on the NC I could only hear people close by and fairly soft. With music on at a decent volume nothing. With NC on the impedance of the headphones goes up from 30 ohms to 150 so the V20 does boost up to high impedance mode but keep in mind that's it's misleading to call these headphones high impedance because the impedance changes because the headphones internal amp kicks in for the noise Cancellation. I'm also led to believe based on what I've been reading that with NC on its not relying so much on amplification from the V20. Having said that there is a noticeable difference between normal and high impedance mode, and while it's not leaps and bounds compared to trying it with cheaper headphones but it is a difference I appreciate. There is a big difference when I turn off the quad DAC and run off the snap dragon DAC. I also tried them with the G5 and I could actually listen at full volume in that case. That tells me that what I'm reading about the headphone amp ignoring the V20 boost can't be completely true. I can't run the V20 at max volume without hurting myself.
Now... The sound quality. With the Native music app the run a bit flat but still very pleasing to the ears and the senses. I can hear so much stuff that I never heard before. Even more so than what I had already gained with the V20 with cheaper headphones that I already owned and the H3s. Running Power amp gets you more sound curvature. I love the clean bass on these things and the highs and minds are intensely bright. Depending on the song I can feel the vocals as if they are singing right behind. Not only am I hearing sounds I never heard before I can hear them all together. I tried the flac and mp3 files... I have Spotify premium for a few more days and all these formats sound amazing. I realize flac is better but I stand by my early feeling on this phone that it makes good work of some of the lower bitrate files. I will give some credit to the headphones themselves but these combo is a beast. I even listened to a YouTube video I like and was blown away once again by the difference. Again I love the clarity of all the different sound frequencies including the base. If you are a base head though they are not for you. I tried some of the Sony extra bass Models and they were not for me. Sorry but I can't deal with mud.
Right now I'm loving these but I have 30 days to return as long as I don't damage them do I am planning on listening to some other stuff at Guitar Central since they carry Beyers and B&h doesn't.
I hope headphones doesn't become my new addiction but I'm depressed that all of these years I didn't know what I was missing in the music.
affansahab2021
